[?]: how to replace printer attached to CP340?
hmohamed
Post by hmohamed » Wed Dec 02, 2009 8:27 am
Dear all,
Please i need information for how to change an old printer [Epson] attached to CP340 Module
what i should do to replace this printer with a new printer
greetings
Hosam
greg2008
Re: how to replace printer attached to CP340?
Post by greg2008 » Wed Dec 02, 2009 1:39 pm
which interface has your cp340?
hmohamed
Post by hmohamed » Thu Dec 03, 2009 8:22 am
Serial interface
greg2008
Re: [?]: how to replace printer attached to CP340?
Post by greg2008 » Fri Dec 04, 2009 4:55 pm
Any matrix printer with interface rs-232: Epson (example Lx-300), Oki. Serial interface (may) be an additional option. Detail in catalog manufactor (producer) Printer
hmohamed
Post by hmohamed » Sun Dec 06, 2009 10:29 am
yes thank you i think this is a good solution
but i want to print the data into A4 papers not into dot-matrix
so can you help me to know how to do this?
thanks for your time
greg2008
Post by greg2008 » Sun Dec 06, 2009 6:42 pm
You must use a printer that can operate under the MS-DOS. Look at OKI (see model Okipage 12i, 14ex, 14i, 16n, 20, 24). We must have a serial interface for printer or use the CP340 with printer interface, or convertor serial to parallel interface (Rs-232 to LPT (centronics)). You can use epson termoprinter.
p.s.
I not use printer with Siemens, I analize Compatibility interface (hard & soft)
