[?]: Floating point S7 to S5
JanLand
Post by JanLand » Mon Mar 30, 2009 1:21 pm
For a project I'm working on now I need a softwaretool to convert the S7 real format to the S5 real format, I know thah there is tool
See below, but mayby someone has written software which he likes to share.
See siemens automation site ID25629271
http://support.automation.siemens.com/W ... n/25629271
but is not free Image
Converting floating point numbers between the S7 and S5 format
Since the S7 real format differs from the S5 floating point format, it is not possible without conversion to adopt the formats into the respective other controller. Functions "S7ToS5-Floating" and "S5ToS7-Floating" are available for the conversion into the respective format.
Thanks in advance,
Jan.
gruendolf
Post by gruendolf » Wed Apr 01, 2009 9:14 am
Write your own converter or try this:
http://www.plctalk.net/qanda/showthread.php?t=4791
JanLand
Post by JanLand » Fri Apr 03, 2009 6:50 am
Hi Gruenendolf,
thanks for your input on this topic, I already known the topic you mentioned, thanks for your help
